Menu
Home
Forums
Search forums
Log in
Register
What's new
Search
Search
Search titles only
By:
Search forums
Menu
Log in
Register
Home
Forums
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
GTI-R Owners Club | GTIROC
New posts
GTI-R Images
GTI-R Images
General
General GTI-R Discussion
Threads
4.7K
Messages
60.5K
Threads
4.7K
Messages
60.5K
Howdy
Yesterday at 9:08 AM
vpulsar
New Members
Private
Club News
Private
Website - Features / Bugs
Private
Members GTI-Rs
Private
Spotted!
Private
Useful Links
Threads
113
Messages
755
Threads
113
Messages
755
Injector cleaning by post - A1 service
Sep 4, 2020
Insurance
Private
Buying & Selling
Cars
Threads
705
Messages
8.4K
Sub-forums
Sub-forums
GTi-R Cars For Sale
Other Cars For Sale
GTi-R Cars Wanted
Threads
705
Messages
8.4K
Testing the waters
Jul 7, 2025
Parts
Threads
3.9K
Messages
19.4K
Sub-forums
Sub-forums
GTi-R Parts For Sale
GTi-R Parts Wanted
'Rbay
Threads
3.9K
Messages
19.4K
Steering rack/pipes
Jul 6, 2024
Sailor96
Group Buys
Private
Shows, Meets & Race Events
Shows And Race Events
Threads
563
Messages
9.9K
Sub-forums
Sub-forums
International Shows/Meets
Japanese Tuning Show
JAE
Japfest
Jap Show
Motorsport
Other Shows & Events
Ten Of The Best
Time Attack
Track Days
Trax
Threads
563
Messages
9.9K
Drag Racing the Pulsar my disastrous 3rd year (what makes a champ)
May 28, 2024
Regional Meets Section
Sub-forums
Sub-forums
England - North
England - Midlands
England - South
Ireland
Scotland
Wales
Private
GTiR Wiki
Technical Questions
Threads
3.5K
Messages
35.4K
Threads
3.5K
Messages
35.4K
Throttle body nipples query.
May 13, 2025
Chris1
General
Threads
745
Messages
10.6K
Sub-forums
Sub-forums
Buyers Guide / Part No's / Specifications
Boost - Questions / Problems
Compression - Ratio / Problems
Detonation / Knock / Pinking
Hestitation / Misfire / Holds Back / Idle
NME / Rally
Nitrous Oxide
Overboosting
Overheating
Overfuelling
Rolling Road
Servicing
Starting - Problems
Track Days / Preparation
Weights / Weight Saving
Threads
745
Messages
10.6K
Fuel Pump options.
Jan 8, 2024
Electrical and Lighting
Threads
1.9K
Messages
15.4K
Sub-forums
Sub-forums
Battery
Boost / Fuel Controllers / Performance Meters
Dashboard / Interior Lights
De-Limiter / Converter
ECU / Chip
Fault Codes
Fuse / Relay
Gauges
Headlights / Front Fogs / Spots /HID's
Indicators / Side Lights
Mapping
Rear / Fog Lights
Sensors
Turbo Timers
Wideband
Wiring
Threads
1.9K
Messages
15.4K
L
Fault code check procedure
Dec 22, 2023
LeeSmith
Engine
Threads
7K
Messages
62.6K
Sub-forums
Sub-forums
Air Filter / Panel / Temp
Alternator
Actuator
Bearings
Belts
Bleed Valve
Charcoal Cannister
Cold Air Feed
Camshafts
Carbon Cannister
Clutch
Conrods
Cooling / Coolant
Crankshaft
Dump Valve / Blow Off
Engine Bay
Engine - General
Engine Mounts
Engine Problems / Noise
Engine Rebuild
Exhaust
Fans / Fan Switch
Flamer Kits
Flat Spot
Flywheel
Fuelling
Fuel Filter
Fuel Pressure / Regulator
Fuel Pump
Fuel Rail
Fuel - Surge / Swirl Pots
Fuel Tank
Gaskets
Gearbox
Head / Gasket / Bolts
Hoses/ Clips - Silicone / Standard
Idle / Tickover Problems
Idle Control Valve
Ignition - Distributor / Timing
Ignition - Coil / Packs / System
Ignition - HT Leads
Injectors
Intercooler
Lamda
Lifters - Solid / Hydraullic
Liners
MAF / MAP / Lambda /AFR
Manifold - Exhaust / Turbo
Manifold - Inlet
Oils
Oil - Breather / Separator / Catch Can
Oil Feed / Drain / Dipstick / Pipe / Restrictor
Oil Cooler / Filter
Oil - Pump
Oil - Temp / Pressure
Oil Leak
Oxygen Sensor
Pistons
Propshaft
Pulleys
Radiator
Rocker
Shims
Smoke
Spark Plugs / No Spark
Starter Motor
Stroker Kit / Other Engine
Sump
Tappets
Thermostat
Throttle
Timing - Chain / Pulley / Temsioner
Torque Settings
TPS
Turbo
Turbo Elbow
Vacuum - Hose / Problems
Valves - Stems / Seals / Springs/ Guides
Washer Bottle / Jets
Wategate
Water / Coolant Leak
Water Pump / Injection
Threads
7K
Messages
62.6K
True bolt on turbo?
Dec 9, 2024
johnny gtir
Exterior
Threads
783
Messages
8.3K
Sub-forums
Sub-forums
Badges
Body - Panels/Respray/Paint/Vinyl/Stickers
Bonnet
Bumpers - Front / Rear
Carbon Fibre
Chassis
Doors / Tailgate
Exterior / Bodywork
Grill
Mesh
Mirrors / Windows
Mudflaps
Noises
Number Plates
Side Skirts
Splitter / Spoiler
Sunroof
Wheel Arch / Trim
Windscreen / Wipers
Wide Arch / Body Kits
Wind Deflectors
Threads
783
Messages
8.3K
Spoiler caps
May 3, 2023
Handling / Braking
Threads
2.2K
Messages
20.4K
Sub-forums
Sub-forums
Suspension Setup
ABS
Ball Joints / CV / Lower Arms
ARB - Anti Roll Bar / Anti Lift
Brakes
Bump Steer
Bushes
Camber
Caster
Coilovers
Drivetrain / Driveshafts
Droplinks
Handling
Hub
LSD / Differential / Transfer Box
Lowering
Power Steering / Rack
Top Mounts
Track / Tie - Rods / Ends
Tyres
Tyres - Slicks
Springs
Strut Braces - Front / Back / Lower
Suspension / Shocks
Wheels
Wheel - Alighnment
Wheel - Bearing
Wheel - Offset
Wheel - Spacers
Wheel - Stud
Wishbones
Threads
2.2K
Messages
20.4K
Rear Brake Options
Mar 21, 2023
splmum
Interior
Threads
616
Messages
5.2K
Sub-forums
Sub-forums
Air Conditioning / Heater
Carpet / Mats
Central Locking
Clocks / Dials
Dashboard
Door Cards
Gauge Holders
Horn
ICE and Security
Interior - General
Leather Interior
Pedal Box
Rev Counter
Roll Cage
Seats / Harnesses
Speedo
Steering Wheel / Gear Knob / Pedals
Threads
616
Messages
5.2K
Standard factory fit Speakers (pics here)
Aug 30, 2023
Jon Olds
Group N / Group A
Threads
13
Messages
57
Threads
13
Messages
57
'Lombard' Rally festival 3rd July Brunton airstrip North northumberland
Sep 28, 2023
Jon Olds
Latest posts
Howdy
Latest: vpulsar
Testing the waters
Latest: fubar andy
Jul 7, 2025
GTi-R Cars For Sale
Feeling hot hot hot!!!
Latest: Cathode
Jul 1, 2025
Turbo gods Help! Turbo Rebuild Mismatch
Latest: Sailor96
Jun 30, 2025
GTI-R Registry
Latest: fubar andy
Jun 30, 2025
Forum statistics
Threads
38,294
Messages
398,221
Members
4,141
Latest member
VERLINDEN
Home
Forums
Accept
Learn more…
