MAF Sensor regrounding
Fire & skill
Vintage member
just di this to a mates car - i dont know if its made a difference TBH, although the reading is right now, still idling lumpy
stevepudney
GTiROC CHAIRMAN
What are the symtoms of a MAF that needs (reads over the 9mv stated) to be re-grounded/earthed. Anyone who's done this have you noticed any benifit at all.
stevepudney
GTiROC CHAIRMAN
Just had a Z32 MAF fitted to my car and suspect it needs grounding properly. Problem is under the rubber cover on the plug there's 4 wires, white, black with white band, black and another white, how do I tell which is the earth ???
AJ4
measure the resistance between each of the pins and ground ( with the loom connected and ignition switched off ). One of them should be about 1 ohm, thats the one.
Also, just found this in another post -
Pin B - White Wire (MAF Signal)
Pin C - Chassis Ground (Connect this to any ground on the chassis)
Pin D - Black Wire (Harness Ground)
Pin E - Black/White Wire (Power)
stevepudney
GTiROC CHAIRMAN
Cool, cheers Ross :)
This is what I got on my plug :?
Pin B - White Wire (Thin wire)
Pin C - Black/White Wire (Thin wire)
Pin D - Black Wire (Thin wire)
Pin E - White Wire (Fat wire)
Now I'm confused :? Need to get the Multimeter out me thinks :roll:
stevepudney
GTiROC CHAIRMAN
Right, just had a look to see if I could find the ground wire on my Z32 plug, with the Multimeter set on the 2000 ohm setting and the cable layout as above post, I get a 1 ohm reading on both the black and the black & white wire :?
Trouble is if I connect to the wrong wire I will distroy my MAF, am I using the corrrect Mutimeter setting ??
AJ4
2000 ohm range is fine.
Here's how I'd work it out.
The pin B wires match up ok ( signal wire ).
The Pin D wires match up ok ( harness ground ).
Pin E is supposed to be live, so expect a thicker wire ( as you have found ).
That leaves Pin C as the chassis ground.
That ties up with what you measured ( Pins C & D are grounds )
Is it too late to leave a disclaimer ? :D
B
boozyboo
went to the tuners, they pluged my car and got a reading of 315v to the maf from a 12v battery. work that one out:der:
:lol: You'll never see 12 volts at the MAF...... You'll see a range of 0 - 5 volts, depending on how much air is flowing through it !
Paul
B
boozyboo
Paul
i watched the computor. it fluctuated from 3.2v to 315v (thats not a typo) to the maf.
that would have been 3.2 volts to 0.315 volts. How do you think the MAF ups the voltage to 315 volts ? That would burn out most of the delicate circuitry !
Paul
STU4X4
Think Im Getting My Wires Crossed Here, (no Pun Intended)
Ive Got A Standard Maf Fitted And Its Only Got 3 Wires, 2 Oute Are Orange And Middle One Is White.
If The White One Is The Signal Back To The Computer Why Is It Now Being Put Straight To Earth?
philpy
For those of you that have reground your MAF did you:
Cut the existing white wire and take it from the MAF plug straight to the ground, therefore leaving a dead tail in the wiring loom.
Or
Just add a spur to the existing white wire leaving it intact but with a new ground nearer the MAF.
Just wondering if this makes a difference.
Or
The only difference it should make is neatness matey.
I did the second one so, reinforcing the existing earth.
Paul
