Knackered Fuel Pump??
R
RS_Cosworth
What are the tell-tale signs of a Fuel Pump being on its way out??
My 'R does not like it at all when I try to accelerate & it comes on boost (in any gear), to the point where it feels like it hits a brick wall performance-wise and in some cases even cuts out completely. It's had a new fuel filter, plugs, leads, dizzy cap & rotor arm and still no joy :frusty: Does a new Fuel Pump sound like a sensible next step or has anyone got any other suggestions what could be at fault?? :cry:
R
RS_Cosworth
Cheers Fella, I may be interested in it I'll get back to you.
Just to add to the symptoms of what my car is doing aswell which I forgot to put in my 1st post, when I planted my foot in 2nd gear earlier today it just let out an extremely loud backfire and black smoked??!!
R
RS_Cosworth
turboloon said:
your lambda sensor could be knackered...
Oh right something else to think about, cheers for the input turboloon :thumbsup:
What boost are you supposed to be running?
What plugs and gaps are you running?
Have you checked all the boost hoses for leaks/security, missing wastegate hose ect?
Do a fault code check. There's a sticky at the top of this section.
