yes mate very easy the two pipes next to each other on the standard solenoid just remove them insert something in both ends to join them together either a inline connecter (halfords,motorworld etc) or use smaller diameter hard plastic tubing (send me a pm if you want some i have loads of smaller diameter pipe)
then just leave the standard solenoid as it is with the wiring still connected but obviously with the two pipes removed. and there you go, would only advise this if you have a aftermarket boost gauge though so you can monitor the pressure.
hth
regards
nick
