Thanks! apologies i never thought of doing that........ anyway i get somewhere near 30mm but i cant get straight onto the disk without removing the wheel. The brembo disks are 33m from disc face to top of bell so maybe they will fit.....:?On gtir, face of disc to face of bell is approx 23mm. Measured through my spokes.
It's raining here too ya know. ;-)
If they are measuring the height the same way as me (from disc face to top of bell) then it looks like I've got the right discs.Gtir Disc
Specification
A (Diameter in mm): 258
B (Thickness in mm): 9
C (Minimum Thickness in mm): 8
D (Height in mm): 33
E (Centre Bore in mm): 68
F (Number of Bolt Holes/Stud Pattern): 4+2
All brake discs are supplied as a complete axle set (one pair)tir disc
If that's the case its the wrong disksHeight is normally overall.
So you need to subtract the disc thickness ( 8 or 9 mm )to get the face to face measurement.
Unfortunately that is the point they are arguing; that these discs will fit a Sunny GTIR and that they need to speak to Brembo to confirm that they do/don't. A quick look on Brembo's website shows that they don't list a disc for the Sunny GTIR but they do for the GTI. The part no on the website matches the part no I have on the box. The box even says GTI not GTIR!Tell them the parts they've sold you are not fit for purpose and if they can't replace them with the correct parts you expect a full refund. - Sometimes you have to be a bit of an arsehole to get people to do the right thing.
