Right,ive had an autoelectrician look over my car and he still could not fix it! (yet) he was looking at it for 4 hours and charged me £120
anyway the car still does`nt work but he did find a couple of faults. the first thing was there is a fault to pins 38 and 47 on the ecu,the fault is that there is no 12v at the pins, so what he done was he put a fused 12v on the wires from the ecu and this gave a spark so we were finally getting somewhere.
the next problem was to get the fuel pump to work so what he did was put a seperate earth on the fuel pump pin(104) on the ecu which made it work. We turned the engine over a few times and still nothing and we also found a constant 12v at the injectors even with the ignition off! if u unplug the plug to the resistors found ontop of the passenger side wing in the engine bay covered by a crome plate theres 5 wires 4 goto the injectors and the other one (white cable) feeds the injectors 12v. so guys im stuck again has anyone got an idea of what to try next? could it be a faulty ecu??????? please help im going mad :x
