Dribbling washer jets
Stoned
Ever since I have moved the washer bottle to the boot I've noticed the washer jets at the front dribble fluid when taking corners quickly or braking harder. It's a bit annoying as it drys and stains
Does anyone else get this after moving the bottle to the back?
I dont really understand why because the bottle is below the level of the jets themselves so it's not like the fluid would travel down from the bottle :?
AJ4
try turning the bottle round so the outlet is facing the rear of the car first before looping back towards the front
N
Norfy
you can get inline one-way valves that would eliminate this problem :D prob from halfords or the like
Stoned
How would that work
Wouldnt the valve close to stop the water comming out, and therefore stop the jets working as well? :?
Nope I don't get any problem like this :wink: And I'm running both pumps to the front washers :D .
rob
Mr Overboooost
just change the washer jets and that should cure it after all they are getting on a bit :lol:
cheers
gary
Stoned
Nah I think you misunderstand
The jets work fine when I turn them on. The problem is they leak water when NOT on, under braking and turning corners etc.
Mr Overboooost
zid336 had exactly the same problem they worked fine when used but they dribbled under normal driving so i replaced the offending jet and it was fine.
hope this clears it up :D
cheers
gary
D
DOT2DOT
Norfy said:
its a one way valve. lets fluid out but not back in
I love your idea mate, but he's not worried about water leaking into the bottle!! :lol: :lol: :lol: Classic post!
