It all depends what you want to do, and how much money you have, and also how many risks you are prepared to take.
Some people can run 1.2 bar all day, others have had engines blow up running 1.2 bar.
A Friend of mine runs 1.1bar max(having had his fuelling checked at DP) on his 'R & thats with HKS S40 plugs, Walbro & HKS EVC4. For more, he'll be using an F-Con.
I'm running on Denso IK24 plugs with a Walbro & a GReddy Profec B set to 1.0bar max. For more power/boost I'll be using an SAFC & S-ITC ( to adjust timing...also important
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Its not worth skimping on £60-£200 of equipment to run 1.2 bar & blowing your engine up, costing a lot more than £60-200 to fix :?:
One alternative to the SAFC & SITC or a piggyback unit such as e-Manage, GEMS, Power FC or Motec is to fit a replacement daughterboard from (
http://www.japaneseperformanceparts...32_38&osCsid=942b09b5d08a6b6a505a3083bf38047a) to your car (together with uprated injectors for the 2nd board). This comes pre-programmed to run 1.2 bar tops with the following mods : filter, exhaust, boost controller & 550cc injectors.
Definately get a Walbro to maintain the fuel feed to the engine & better plugs if nothing else.
