R
riske
Could be a little animal screaming for its life hanging inside your arch... thats just my 2 pence worth
wasnt even driving it hard, just driving home from work, went to change up from 4th to 5th, took it out of 4th then nothing.Get an uprated gearset or change the way you drive and take it easy on your box.
yeah, i'f it was me i'd buy the hub and the clips new (about £40-50 from memory ). I wouldn't use a second hand one as like i say, its quite common for them to crack.can i still get these parts from nissan?
Would it not be worth having his g/box and contents parts cryo treated or shotpeened before its put back together for added strength?yeah, i'f it was me i'd buy the hub and the clips new (about £40-50 from memory ). I wouldn't use a second hand one as like i say, its quite common for them to crack.
the hub is the bit that you now have in 3 equal sized pieces and 2 smaller splined broken bits in your photo.
i may have the other bits in my garage, will have a look for you, if you've got a bearing/gear puller its not a hard repair tbh.
