Evo 3 brake.. want to post it brake topic at Tuning and up
cmng
Just to mention
Evo 1-3 Twin pot brake is plug and play for GTIR
you need to use Evo rotor as well
it is 276 x 24 mm size
drill the rotor to PCD 100 x 4
the on the mounting
it plug and play just need to bore a bit bigger the caliper lug on one side only
it very popular conversion at malaysia for Sentra Owner
By the way
Evo 1-3, VR4 RS 2 pot all can use
ALL MITSU Caliper with 2 pot caliper and 276 x 24 mm disc is FIT
sorry
this is disadvantage of non paid member
Some one please copy this to the Tuning and upgrade
and brake upgrade topic
Thank
ashills
these brakes are good on my evo 1 i never upgraded the brakes apart from some new pads i was trying (very good they were aswell) and i had no trouble atall at bruntingthorpe stopping from over 160
cmng
err it very easy
you get hold a EVO 1-3 caliper and compare it with RNN14 caliper
then you know it will be DAMN easy
it just about 1mm different only on both of the caliper mounting
overall you can said all
Evo 1-3 brake upgrade will fit RNN14
i not sure on E4 and E5 brembo above
ashills
the evo brembo calipers are very wide so idoubt they would fit but might be worth a try as they will go on teh evo 1-3 with a spacer but is very very tight
cmng
i asking my evo friend to check on this
update the status
since i not familiar with Evo related
Fire & skill
Vintage member
Re: Evo 3 brake.. want to post it brake topic at Tuning and
cmng said:
Just to mention
the on the mounting
By the way
Thank
thanks dude!! this is a great help - i am going to try this conversion on my car :wink:
Sweeny
8) this is good news
evo 1-3 calipers will go up in price when the evo owners catch on :lol: :roll:
abyss
i have found a site that shows a picture of the inside of the caliper apart from being a 2 pot it looks identical to the pulsar caliper.
gtir bean
i have found some calipers so just need to get a price for some disks.if there not bad this will probably be my next mod.
cmng
no
it large surface
you can compared it with those other nissan twin pot caliper like
from U13 SR20DET or those Cefiro A33 or A32 twin pot
it same caliper but different mounting
using Mitsu version will fit it directly
a feed back from my friend that
EVO 4 twin pot and rotor also fit Evo 3, just need to redrill the rotor only
Evo 4 is 295 x 24 mm
and Evo 5 and above brembo will fit to Evo 4 plug and play
so if this informantion is correct
it is high chance that Front Evo brembo will fit to RNN14 plug and play
this is what i was told
will verified it asap
will update the status when i manage to get my friend to measure his Evo 7 brembo mount measurement
ashills
trouble is the evo 5 onwards brembos are very wide alot of early evo guys who try to fit them need to run large spacers and they are known for being terrible for warping discs
AP even designed a new typr of disc to try and sort the problem but would be interesteing to see if they would bolt up etc
cmng
yup Evo Brembo is know for Warping issue
spacer..
i am sure the caliper clearance is big and need a smaller rim offset or thick spacer if it do fit since looking at the Evo brembo size it is big
Hi just wanted to see if anybody had actually done the Evo 4 upgrade ( 2 pot ) as i have just aquired some and very keen to get them fitted.
Thanks for the response boys however i have got a set of Evo 4 2 pot calipers not Evo 1,2 or 3 and was wondering if anybody had used these. As above post by cmng he said he thought it may be possible.
