JayRA
Which brake pads would you guys recommend for Wilwood four pots and where from?
Thanks for all the help guys, fast B road and the occasional track day driving sounds about right for me, so think I will be going for a set of one of the abovefubar andy said:If your going to be heading more of a fast road/trackday set up then perhaps some Mintex 1155’s, CarboTech XP8’s or DS2500’s.
I’ve got the “test kit” 304mm K-Sports 6 pots on my car coupled with the DS2500’s.GTiRlover said:fubar andy- I am using Ferodo DS2500's on the front of my car at the moment and must say that the braking is more than adequateHave you used these pads on the track? If you have what are your opinions, are they consistent or do they fade quickly?
How much extra performance do the DS3000's offer and is the wear rate any faster? I am aware the 3000's are intended for track use but how do they fare on the road? I presume they need some heat in them to start working at their best?...
Thanks for the reply. To be honest I wrote that question very single mindedly, I hadn't taken into consideration the weight of the car or the braking system using the pads. Although you say the DS2500s fair well on track which answers my question.fubar andy said:I’ve got the “test kit” 304mm K-Sports 6 pots on my car coupled with the DS2500’s.
As a trackday pad they faired up well. No major issues with fade and the ware rate was slow.
However there are many different factors that may be different to your car than mine. The fact that I have 304mm 28mm thick discs help a lot disperse heat rather than my older 280mm 24mm thick Wilwoods 4 pots that suffered heat build up far too easily. :doh:
As I mentioned before, weight is also a factor as my car weights between 1050-1100kgs there is a shite less mass to slow down so the pads don’t have to do too much work. Where a full weight GTiR would need more grip from the pads to slow it down.
My personnel opinion is try out your DS2500’s on track. Dependant on what brake system you have they should be ok, again this also depends on how you drive and how hard you brake!
Bob (pulsarboby) mentioned that the DS3000’s are not really suitable for road use, so you could always have a spare set for track and one for the road like I do! ;-)
If the DS2500 are failing on track, make sure you’ve uprated the rear pads, I’ve read about people who say the rear brakes do hardly any work, I would like to differ as I’ve personally seen mine burn the backing plates – these were uprated pads too! So its well worth looking at sorting something out as well, also braded lines all round.
If all else fails then a nice set of DS3000’s might be the trick, but always look at other areas before whacking in a hardcore set of pads.
I've not used DS3000's but I have had Mintex 1166's and these are a simlar compound ;-) good on track crap on the road and they squeek like mad!
GTi-R23 said:How do you find the DS2500's from cold Andy? I'm not overly impressed with my brakes at the moment tbh, I'm running Wilwood 4 pots on new 310x28mm discs and DS2500 pads, with new black diamond disks and pads at rear, just doesn't give the braking performance i was hoping for, seem to work better once really heated up. Already have braided lines and calipers seem to be in good nick. Have to really press on the pedal to slow up fast, is this usual for R's, needing alot of pedal effort?
Only drove a few others and they were standard brakes so were useless anyway.
Pardon my French but fúck the percentages! :lol: I previously used to read about the percentages and its more misleading than the figures make out!GTiRlover said:I am guilty of this because I have read lots of people saying that the ratio is 80% front and 20% rear. Is this accurate? Have you had any experience with a braking bias valve, if so what are your opinions?
You've not been on track with Yellow Stuff pads have you? :lol:irishjohn said:ebc yellow stuff pads are good...i have them on my r. my brakes are prety stock though but since fitting the ebc's the brakes are much more progressive and are good from cold...just my 2 cents worth.
fubar andy said:Pardon my French but fúck the percentages! :lol: I previously used to read about the percentages and its more misleading than the figures make out!
Due to the 4WD transmission and there is more rear braking required/used than many people realise!
Ok the percentages might be right, but after burning a rear set of uprated pads on track, this (for me) is conclusive evidence that rear brakes are more important than previously talked about.
Again its all about environment and how you drive, perhaps around town its not going to make a real improvement, but on track when the pads are failing at the rears, some uprated pads will make the car feel more positive when braking/driving and certainly gave me more confidence when hard braking.
I've got no experience with actual brake biases but in simple terms if you uprate your brakes whether is the pad coefficient, bigger disc's, bigger pistons you have increased the front bias so it could be more like 90% 10% (but like I said before I’m not fussed about the figures) However if you also change the rears for better pad coefficient, bigger disc's or bigger pistons this will help counteract the front bias restoring it to similar settings and also giving you better braking for the track/road.
"Perfect brake bias is obtained when the front-to-rear balance of the brake system exactly matches the front-to-rear weight balance of the vehicle"
I've not got that, but its a lot better than is was/is and perhaps in the near future some rear 300mm discs might be on by purchase list.
…but for now I’ll keep on testing/trying out different compounds and set-ups. ;-)
no but i have a track day next sunday...am i in for a nasty surprise?fubar andy said:You've not been on track with Yellow Stuff pads have you? :lol:
I've been on track with ebc yellowstuff pads, it's what I'm running now. Unfortunately, I really don't have much to compare with, but at least I got the "most melted caliper paint"-award on that trackday. :doh:irishjohn said:no but i have a track day next sunday...am i in for a nasty surprise?
