Wheels
T
turbogtir
Does anyone know where I can find out what wheels will fit the pulsar???
Will VW golf wheels fit ???
T
turbogtir
Wheels ofset and Pitch
does anyone know the standard ofset and pitch for the standard wheels and also the centre bore size
4x100 pcd.
offset et40 in the manual, but anything close should be ok.
Hub centre 59.1mm
Websnowbo
If you want to see what wheels will fit do a search on the net, i think Extreme has a list on there website, maybe Halford's.
Can't remember, i found it ages ago but have the memory span of a small orange goldfish who is blind in one eye and has a bowel infection from sucking on lttle stones all day.
madMATT
whoo what size wheels are you aftr mate 6j*15 offset 29.2-50.9
6.5*15 offset range 29.2- 47 / 7*15 offset range 34.5-40.5 /7*16 offset range 34.5-40.5
7.5*17 35-40 rim offset 40/ p.c.d 4*100 centre bore 59.1. try not fitting other manu wheels on as this all will require some sort of adjusting to get fit i.e most astras are centre bore 56.6 ren 60.1 v.w57.1 hope this helps ya dude if you want lets know what youre after and ill try and source did a set of bare 15" alloys to jonee for around £220 allways deals going on ?
