tyres
do u have to change all 4 tyres at the same time or can u just change a pair as my fronts have wore funny on the inside wall
John Mc
If they are wearing uneven get the traking checked, if I was you though I'd get a 4 wheel laser alignment 8) Best thing I did along with the new tyres. Handles really well now! :D
JIMMYBACK
where di u get it done and how much minds in need of it :D
cheers jimmy
John Mc
Tyre fitters do it mate, just ring up and ask. Although you'd probably be better off getting it set up by a suspension specialist. But mine was done in Stapletons in Ware for £21.50 and the car just feels so much better going around corners 8)
i had it laser tracked i think its just cause there poo. its as if the tyres are leaning and wearing on the inner shoulder of the tyre
antgtir
That sounds more like the camber settings to me mate. If you want the tyres to wear perfect then i would have the car laser alligned and the camber settings re-done. However this will probably make the car handling feel a hell of alot different.
Ant.
Mr GTiR
always thought that you could have no more than 2mm difference between front and back tyres :?:
It defo sounds like your camber is out if you've had the tracking done already. there ain't a lot you can do about that unless you've got camber bolts or top mounts though.
You can change as many tyres as you want.... its a free country.
Money no object you should keep them of a similar age and tread depth with definately the same tyre all round. Feel free to put a part worn on ones side though if cash is tight :wink:
Shaun
:D That used to be on the Calibra Turbo's mate,used to scrap the diffs if the tyres didnt match :shock: :shock: :shock:
Mr GTiR
Knew i heard it before somewhere. Why does that not surprise me about Vauxhalls :lol:
s i need some adjustable top mounts but will they fit the tein coilovers allredy fitted to the car but its not actually the treaded part that wearing its the shoulder thats battered
