Ok this maybe a silly question but is the inner race of this bearing meant to turn freely? Mine is solid. The diff spins in it which is obviously wrong.
I have had problems with noises since fitting the modena diff. I never had it shimmed properly but thats my fault. The noise has been so bad now that couldnt I drive it with out shitting myself. I stripped it today and found no play in the bearing attached to the diff but some play with the bearing it the picture. This could explain why it was so difficult to remove the driveshaft as it was not level with the shaft. I am getting another transfer box to start again but I was going to put the other diff back in to try and see if the diff was at fault but whats the point if this bearing doesnt turn. What do you think.
