Torque settings wanted for head bolts with MLS head gasket
Thor
Hi,
i need the right torque settings for the head bolts if i fit a metal head gasket! If i fit the metal head gasket i must loosen the bolts and torque again with turn angle?
Thanks
Sascha
Torque down to factory spec in the way the manual says, (this is what i do) leave over night, then slacken off and re torque to factory spec....I also put molybdenum grease on the threads and under the washers and head bolt face.
Thor
Thanks Danny that is what i wanted ;-)
You´ve told me these steps with the molybdenum grease last year but i had forgot them ;-(
Can i use the Redline Assembly Lube too?
