toluol injection
zia
toluol injection (methyl benzine) has anyone ever used this as a cooling option rather then water? where in the uk can i get this from?
i want to run this to see if its better than water/alchol injection
cheers for any info
zia
lord of the "R"
MarkMc
I thought toluol or is toluene was used as fuel additive to up the octane rating. I think they mix 50/50.
I did not know that you could uses it in water injection system. I thought water injection only used water ethanol mixes.
zia
from the info i,ve found it suppose to work just as well as water
injection,but its mainly used as a anti,knock.
i don,t think you can mix it with water.not many people use it
will have see if it works, if i can source it over here will try it out on my r.
zia
lord of the "R"
