temp prob
C
clarkey
the temp gauge drops when i boost my turbo and then settles when its not running , ne 1 have ne ideas wot it could be
cheers
Stevo
crossed wire maybe!!
sounds like its acting as a boost guage :cry:
check ur fuses to make sure none are cracked, and make sure or relays are in tightly.
Do your fans kick in??
C
clarkey
there all fine all ready checked the m, the fuses etc r ok as well. i think it could be a temp sensor fault ???? ne 1 had trouble like this before
C
clarkey
C
charlie
Common fault- just clean the plug on the back of the sender unit up. You might even get away with just wiggling it
gtir303
clean up the connectors and check the earths mine had aproblem that when u reved it the temp gauge moved like the rev counter
C
clarkey
cheers will do. might sound thick here but where is it positioned ?
C
clarkey
