		AJ4
Not sure where else to put this, and its only of interest to Steve but someone else might find it useful.
I'll let Steve add to this if he wants with the setup and history of the problem, but basically he was getting an odd flutter at a certain RPM range that was holding the car back.
The problem seems to be that the MAF he is using is not scaled properly in the PFC, causing the engine to knock. In the graph below, the point at which the AFM voltage flutters and the point at which the knock starts is when the engine load is over 27000 ( scaled on the PFC ). Basically what we think is happening, the load is going off the scale and the engine is possibly running lean as it doesn't have a load point to referance for the fuel.
As soon as the load came back under 27000, the AFM voltage flutter and knock stopped. The load peaked at 30000 and the trace can be seen disappearing off the bottom of the screen.
I think the first thing to do is re-scale the MAF so that the load stays on the map, and see if that cures the problem ? Don't rush out and buy a Q45 just yet
Any comments, thoughts, suggestions welcome.
Ross.
Ross.
