slow rev counter
williams
anybody had a problem with their rev counter needle moving too slow? im expecting it to be the clocks just wondering if anyone else has had this and what was causing it?
there are no wiring problems from what i can see.
Trip
what do you mean by slow ?
do you have any other electronic equipment connected to the RPM signal ?
williams
its doesnt keep up with engine speed. if you hold revs at say 400rpm, it will eventualy get there and settle but doesnt keep up with engine. then let the engine drop to idle and the needle takes alot longer to drop to idle speed.
williams
lol, i'll try yours in next time your over.
not sure if it worked when i got it as the car didint have an engine in.
shroom
Has it got white dials fitted? mine does this aswel as the mph so it is pretty anoying. Probably just easiest to swap the clocks or maybe take it apart a bit and see if its just sticking
