shims
gtir bean
how easy is it to do the shims in the head?had my car sitting next to another r tonight and mine sounded like a bag of spanners!
ard1ey
Never done it, but it sounds like a swine to do. :twisted: This is a quick overview...
You need to check the gaps with the engine hot, so warm it up - now pull off the top mount and the rocker cover without injury and check the gaps on all 16 rockers - 2 places on each rocker :shock: according to the book. If any gaps are out of spec, you'll need to remove the problem shims, make a note of the thickness and order new ones. When (if!) they arrive, build it all back up and recheck the gaps with it warm.
Oh, and if the cams or rockers are worn you should change them too, just to make it more annoying :D
I think mine might need doing in the not too distant future.
Sometimes when its hot it sounds like a skeleton having a w a n k in a biscuit tin :(
