AJ4
Seems like quite a few people have got new shiny Power Fc's, so I thought I'd start a thread for anyone having problems with them ( like me
Good bit of advice - If you dont have an Apexi boost controller ( you are using a Greddy or similar ) you will have to deselect the 'Apexi' option in the boost settings menu. If you dont then the car will start but will not run for more than a few seconds before conking out
When you first start the car you are supposed to do a self-learning idle setup. Basically this means run the car for 10mins with no electrics on, switch the rear demister on for the next 10 mins and for the last 10 mins switch the aircon on ( 30 mins altogether ). It idles rough as anything for a minute at first but soon settles down as it learns.
I worked out some of the other settings ( manual is all in Japanese
). When you look at the rev/idle menu, the first limit is set to 7500 rpm, this is the rev limit. The second limit is also set to 7500 rpm, this is the launch contol limit ( I set mine to 5500 rpm, ignition cut with full fuelling = huge flames
The idle limit is bit hard to work out - the first is set at 900 rpm and the second is set to 950. I think the first one is the limit, and the second one is the actual value you would like. Without changing it, my car idled at 1200 rpm like its always done ( the pulsar curse.... ) but kept fluctuating up and down between 950 and 1200. When I move the limit up to 1250 rpm it cured it, and it idles lovely now.
To view the system parameters, select monitor ( obviously
) and it will take you to the display screen. If you hit 'next' while showing the parameters it takes you to the rolling 15 second display screen, which is excellent for checking the knock sensor output
A question I do have though - the car is not a quick as before, but I've notice my ignition as measured and set on the commander is 40', not 20 as its supposed to be. I tried a 20' correction to bring it back down to 20 again but it ran even worse. Anyone know anything about this ??
Anyone with a full English manual for the FC and Commander or more hints and tips on setting it up ??
Ross.
Ross.
