rear washer
LeeSmith
723
1
18
38
Bristol, Uk
I've noticed there is only one fuse for the washers...so that rules that out....so i guess it's either a blockage or the pump could be broken/disconnected???? n e 1 else have any comments/help???
jasegould
usually its the pipe that breaks as it flexes every time you open/shut the boot. A sign of this is puddles of water under the car when you use the washers.
Can you hear the pump working? If not start there, take it out and zap it with a supply, see what happens
LeeSmith
723
1
18
38
Bristol, Uk
LOL! I totally forgot about this problem!! Shows how clean my car has been kept since November!!!! my switch seems to only operate the front washer jets - should it do one or the other depending on what way you turn it? Also, on the front - when i pull the lever back i get 3 swipes of the window wipers but no spray of water! Wierd......
R
rx7rotary
gotta same problem actually. no water coming out, and wipers work fine!
hmmmm
