Rear brakes
keensie
Ok so i've just rebuilt the wilwood calipers and then went to bleed the system,problem is i can't get fluid out of the rear drivers side i have disconnected the hose to the caliper and theres nothing pedal just goes hard,is there a valve or something as all other corners are fine?
If you're struggling I can see if I've still got the ones that came off when I put braided lines on. - I've got no idea what state they're in though.
keensie
Problem is I've got braided on the front but no one sells the back separate only as a whole kit,I'm going to try rally design as they made up the fronts. I'll keep you in mind thanks.
Obviously your best bet is someone who hasn't left them in the shed for a few years... but desperate times and all that.
If you speak to Goodridge or Hel they will make them up for you.
They'll prob's need a rear brake line to see what fittings they will need and how much pipe to use.
Mine were made at a local motorsport shop in the same manor!
keensie
what's involved in changing both rear brake lines front to rear?i'm fitting braided lines and the steel lines are corroded.
