F
Fusion Ed
Can do:AJ4 said:I've been looking into this in a bit more detail, and I think I can get away with paralleling the standard ones and still stay in spec ( can someone check my figures ?)
Ok so far but the resistors won't have a tolerance of 300%!!!Dropping resistor = 5 to 7 ohms
Injector = 1 to 3 Ohms
Assume V+ = 14 volts
Min possible resistance = 5 + 1 = 6 Ohms
No, lowest current condition would be 7+3 (10 Ω) not 7+1 (8Ω)Work out power required for each injector -
Lowest injector power required is when resistor = 7 ohm, injector = 1 ohm. This gives total resistance of 8 ohms and total current of V/R = 14/8 = 1.75 Amps.
Min power total = P=V²/R ∴ P = 14²/10 = 19.6 W per injector. or 1.4 Amp.Minimum power required to fire injector is therefore = I2R = 1.75 * 1.75 * 1 = 3 Watts.
Min power total = P=V²/R ∴ P = 14²/6 = 32.6 W per injector. or 2.3 Amp, as you have.Max power per channel is when resistor = 5 and injector =1 = 14*14/6 = 32.6 Watts
Incorrect, Take worse case sinaro from above. Inj = 1Ω I=2.3 ∴ V=2.3 (V=IR) ∴ P=5.29 W (P=IV) per injector.Two injectors per channel at 3 Watts = 6 Watts.
No, its 32.6-5.29 = 27.31 Watts - for a single injectors using your worse case values.Dropping resistor has to dissipate 32.6 - 3 = 29.6 Watts.
This falls over now as your values are not correct.If injector total resistance = 1 ohm and power dissipation is 6 watts, then the resistors must have 2.45 Amps running through them, 1.23 Amps each.
To effectivly open the injectors you need to keep the current flowing through them the same as it should be so, to take your worse case values. (its not the same in pratice)
You have worse case 0.5 Ω You need a current of 4.6amps (2.3x2) at a supply voltage of 14.
V across injectors = 4.6x0.5=2.3 (we know that already from above) So:
14-2.3=11.7V Resistance = 11.7/4.6 = 2.5Ω (approx) which you should notice is half the current min of the worse case impedance you wrote above.
Technically no. You cannot add injectors, to a single driver output and expect the ecu to (on the face of it) cope. You need to maintain the current to open the injectors at a fast enough rate, which means you have to ask from more than the ECU was designed for origionally.With 2.45 Amps flowing, and the dropping resistor must dissipate 29.6 Watts, then it must equal 4.93 Ohms.
So if I can keep the paralell injectors to more than 1 Ohm and the resistor to around 5 Ohms then I'm still within the spec of the ECU.
Best of all is to get some high impedance injectors, of 10Ω + and then parallel two of themBetter still would be to find some standard injectors that are just over 2 ohm to give a bit of margin.
Ed
