The reason for 8 is because I dont like big injectors
Without boring you all to death with another techie rant...
The same injector sprays fuel droplets in a variety of sizes, the smaller the injector the smaller the average droplet size. Not all of the droplets are of a small enough size to mix with the air properly and wont combust. Say a 440 injector sprays fuel that has droplets of which 80% of them are combustible, the other 20% dont get burnt because they are too big. With a 880 cc injector that ratio could drop to 60% combustible and 40% unburnt.
That means with a bigger injectors more fuel has to be injected just to get enough droplets that are combustible, so more fuel is wasted. Not only that, the combustion flame has to travel round the larger droplets that wont ignite and slows the combustion speed and maximum cylinder pressure drops, the same way that water injection works. Good for stopping detonation but not good for power
Its common sense that a cylinder where 80% of the fuel volume combusts makes more power than a cylinder where only 60% of the fuel volume combusts. An ideal injector will spray droplets that are exactly the right size for combustion at all rates and none are wasted.
Thats why you always see the advice to use the absolutely smallest size injector you can get away with. People who buy 700 injectors but only really need 550's are just throwing money away, no matter how good it sounds down the pub
The right size injector has more of the right size droplets, combustion speed is faster causing more power, less fuel is wasted and less oil is borewashed off the liners by the unburnt fuel
The reason people use bigger injectors is because its easy to swap them straight in rather than fabricating two fuel rails and the extra electronics etc but its not better for power or fuel economy, the only advantage is it helps to stop det and the extra wasted fuel helps to cool the pistons.
People on other cars ( not heard if it yet on a Pulsar ) move the injectors to the plenum chamber, so the larger fuel droplets smash into the throttle butterflies and break down into smaller more combustible particles. I'm kinda doing the same, with four in the standard position and four in the plenum chamber pointing straight down the bore.
I'm not saying there is anything wrong with bigger injectors, just that they aren't as efficient as smaller ones, and two smaller ones are always better than one single large one. More powerful engines with higher combustion speeds, higher combustion temps and higher intake velocities break down the fuel droplets better so wont make much difference, the only problem is people who fit huge injectors that dont really need them.
I'll just go and put my flame suit on now, for protection from the hundreds of owners who have fitted 700 injectors on their 1 bar Pulsars and swear they give more power
