Photo with inlet top removed
messerant
Does anyone happen to have a photo with just the top of the inlet plenum removed in situ?
I’m looking at options to do the front brake hoses and wondering if top removal will give me enough access!
cheers
messerant
Thanks, but that’s with rocker cover removed - it’s the top part of the inlet removed I was after, so I can see how much extra access it would give me to do the brake lines
thanks tho
cheers
No, but if you can wait a week or so, my plenum will be removed so I can take some photos behind the engine if that helps?
messerant
Thank you for sending those over, I was more so looking to see how much access I would have with just the top cover of the inlet plenum removed as I’m doing g the front brake lines.
however - I have completed the drivers side and fitted the replacement, and so far removed the passenger side ready to make the replacement and fit without having to remove the inlet at all!
so, I’m getting there!
currently looking at where everyone fits there IAT sensor when running stock intercooler as well! That’s on the list once I’ve done the front suspension refresh!
thanks again for following up on this most appreciated!
That's good to know.
Not looked at my lines, but maybe now I should!
messerant
Yeah. Just finished the other side now. I had the wishbone and driveshaft off the drivers side, removed the oil filter and access was enough. To do the passenger side I was able to do it with the intercooler off and the dump valve pipe removed. And my engine still has the Y bracket as well!
Not the best photos but having seen so many struggle with this I thought I’d give some faith at least that it can be done
