part number
stumo
There are 3 grades of "standard" bearing. You will need to look on the crankshaft to find the bearing grade you need.
Each bearing can be a different grade.
Each grade is a slight difference in the size of the bearing.
There's a diagram on this forum telling where to look on the crank (it's on one of the counterweights)
12111-54C00- grade 0
12111-54C01- grade 1
12111-54C02- grade 2
if the crank id used, there's a page in the workshop manual that tells you what bearing to use depending on the size of journal
bestgtir
my crank shaft has the numbers printed on it they are
22322
2122
0228D
soryy 1st time doing an engine rebuild on a pulsar lol.
