Oxygen sencor
stuart rawlinson
Hi All
Oxygen sensor wires Three is the White one the signal wire :?:
All Vote yes or no if no :roll:
Which one LOL
Stu.
zia
1,105
13
38
United Kingdom
you should be able check which it is able using voltmeter.it should switch from 250mv to 800mv at a certain frequency :? hey stu are you connecting both sensor up now? or are you going to use your standard disconnected one? p.s i no longer have one on mine :D
zia
stuart rawlinson
Um i have red black and white
But it does go in to grey after the multi plug as that will do for me Cheers
Zia Motecs fitted then :wink:
No im just seeing wot my second ones doing there just all cut off :? :?
Really dont think the OE one is doing owt they just left it still connected
Just like the Maf was still all connected
Stu
gtiroz
Administrator
292
27
28
Australia
www.gtiroz.net
yes, our standard ego sensor has 3 wires - red, black and white
yes, (as per most R/B/W wiring) red is pos, black is neg, white is signal
yes, if you have a motec installed the factory ego will not be in use
:D
