OSF Wishbone & Brake master cylinder
Yodi
ah so the arm is teh same, use the N13 bush and it will work yeh?
My OSF wheel sits back a bit so want to try the arm first
steve963
no bought a complete GTIR arm for £20, the bush looks hard to get off!
my wheel also was back about 2cm
danr
if u do, send it back and get them to pay for postage. its advertised as GTIR (uk has same bush as import). the bush should have a V-shaped base, not flat. post a pic.
just remove the rear bush and fit a polybush equivelant.
That's a lot cheaper than buying one sold as GTi-R specific! So unless you've got money to piss away on nothing, this is the way to go. - Just look at it; £139 for a GTi-R one, or £20 odd for the Sunny one plus about the same for poly bushes. You're £100 ahead.
