Oil temp and oil pressure Gauges
bopper
Was justing wondering if anyone new the thread sizes for the senders, and i wanted to change the gauges but not sure what size sender adaptors i need
easy! go in a plumbing shop with original senders and say i need a fitting from that to this size, simple as that!
CanadianR
bump. Does anybody have pictures of the stock pressure/temperature fittings? Are they 1/8" NPT by chance?
I want to install aftermarket oil temp and pressure guages. Although if possible, I'd like to keep using the standard emergency oil light "just in case" the new guage stuffs up.
I've been looking at these so far:
http://prosportgauges.com/52mm-electrical-oil-pressure-gauge.aspx
http://prosportgauges.com/52mm-electric-oil-temperature-gauge.aspx
http://prosportgauges.com/52mm-boost-gauge.aspx
And was wondering if anybody had any install stories or opinions on the aftermarket setups.
TIA.
Jamaala1
hey Canadian R i have the those particular gauges at sitting in the trunk of my car. There supposely accurate as the american boys stand behind them. I havent got around to installing them yet, when i do i post up pics.
lilmark
DownunderGTiR - Yea mate it fits the SR20DET engine ive got my oil presure an oil temp of it, but if you get 1 you need to put Plumbers tape on the threads other wise it will leak like mine did cause the little seals are sh1te which come with them
