Oil feed problems
boucherie
I cant seem to get the standard oil feed off my turbo, and to add to my problems the oil feed for the 3071 has got a connector which is slightly too large, so i now also need a connector which is 10mm at one end (to fit the oil line) and 9mm at the other so that it will screw into the turbo. has anyone got one of these or have a part number so that i can get one as i need it asap!!
Have you got any pics of the oil line? Not sure what you mean by 9mm and 10mm connections :? The oil feed thread in the turbo should be 7/16x24 UNF ;-)
Have you got a oil feed restrictor for the 3071?
Dooie Pop Pop
a what?:lol: its just got a threaded hole mate. the oil feed pipe has a fluted look about the end like a claronet. and 7/16 is correct iirc
boucherie
i need to replace the banjo bolt in the block, i think its a 12mm fitting but can anyone confirm/deny it?
