I have been looking into some options to heat the block and oilpan in the cold canadian winter.
I have found some options such as a thread in block heater with an element, where it threads into a frost plug hole.
There is another option, a lower rad hose heater, that goes inline your lower rad hose and heats the antifreeze that way.
The latest I've read about (which is popular with inboard/outboard engine boat owners in the US) is a type of magnetic heater that you can stick onto the side of your oilpan, and it heats the pan and oil.
What I'm wondering is if anybody is already using something like this?
Any benefits to using one type over the other?
And don't bother saying that a heater is not needed, I let the car warm up for 10 minutes the other day when it was only -10 out and the car felt like molasses. (probably did not help that I had redline heavy shockproof in the transmission either) - so I may get a magnetic one to heat the transmission/case and rear setup as well.
any opinions or ideas are appreciated.
