Not starting/cutting out.
G
getlower
Having a intermitant starting problem. Car will sometimes start and run and other time wont. Any common poblems known off. The ecu is fine, but not sue about the airflow meter? Any clues?
G
getlower
Where abouts is this located mate, just saves me routing through.
hmmm
MAF is by the Air Filter and the fuse will be inside by the driver's footwell. Caan't remember exactly which one it is so you'll have to look through them all. Sorry, but at least you'll be able to see if any other fuses are blown ;-) .
Have you tried a fault code check when it's not starting to see if anything shows up?
