My Standard boost is 8psi...How come???
B
beast14
I saw in a previous that it's supposed to be 10.6psi. How come mine is soo low........is something wrong??........i've had a bleed valve on it and when it's closed it reads 8psi.......????.........
J-GTi-R
Have you bypassed the standard boost solenoid when you plumbed in the bleed valve? If so, you'd have only 0.5 bar with the valve closed.
antilag
by adding the bleed valve or adding a thincker diameter pipe u will lower boost cos u r allowing more airflow which makes the actuator open sooner and any restriction in the pipe will do the opposite :D
