Dooie Pop Pop
its not glazing Carl its like there' s a brick under the brake pedal and it doesn' t feel normal underfoot. it only goes down so far and its solid about half way:?
.............................because its you i' ll even go and check:-DFast Guy said:I'm sure mine's similar to that. My pedal is very hard, but it still brakes OK.
Nothing stuck under your pedal?
evo calipers are totally pointless if there' s no braking power in the first place;-) :lol: i lowered it a few months ago when i fitted my whiteline rear arb and gabs:-D i just wanted to keep it simple for the mot mate and to fit those calipers you need to drill the bolt holes hubside because the evo calipers have a larger retaining bolt(s) knowing me i' ll only :mong: it up and have to source new hubs:doh:rayman75 said:what happen to the EVO setup you was going for?
with all that power that thing has got get is sorted asap:-D and get it lowerd at the sametime aswell.;-)
**** it i might as well go get one from Bob and change it, it would be poetic justice for it to be the master cylinder:1bar:stumo said:if your pedal is going hard halfway down and it feels like a brick is under the pedal and the brakes are crap and feel funny then it's got to be your master cyl. even if it is a newish one.
esp afterr changing all the other stuff.
:lol: prick :lol:diesel weasel said:my brakes dont work,
im such a berk,
i dont know whats wrong,
im such a mong
:lol:
sorry if im of no help whatsoever :lol:
:wave: hiya! i have had a good look around under there cheers mate.jsbuds said:i know it may sounds like a mongtard response ol' pop pop but what things havent u checked like even down to the brake pedal mechanism itself and/or and wire connecting it (cant remember the layout of the pulsar now) but i had my van clutch bugger b4 checked everything on it and was still scratching head untill i checked the clutch cable and it had frayed inside the plastic wrapping and was catching on it ! . Also is there any chance of a blockage in any of the lines? maybe drain fluid out and try to purge lines with nitrogen or a dry inhert gas to see if there is any blockage. dunno if it all sounds silly but just trying to help
its newish maybe 3yrs old:roll:pulsarboby said:thought you said you had changed the master cylinder:doh:
have you not? if not then pop down the workshop tomorrow and il lend you one to try on there.
:fu3:stumo said:what a frikkin gimp!
Dooie Pop Pop said:i was hoping someone might have one....;-)
cheers, stu
