If the master cylinder piston was square and 1 inch and you applied 30 pound force , you get 30psi on the piston , if it was 1/2 inch you now get 60 psi .
The fluid acts like a solid bar as it won’t compress and transmits the pressure to the slave cylinder .
Any restriction in the pipe , dent or buckle or restriction in the flexi pipe will cause a problem creating a back pressure .
The slave piston moves depending on the amount of fluid provide by the master .
The load is purely mechanical , the clutch spring load and bearing load , but the forks both at the pedal and the clutch add mechanical advantage due to their length and pivot .
You cannot multiply the hydraulic force other than piston size .
Maybe the flexi is blocked ,maybe the slave has a problem sticking (rust) it’s strange someone changed the rod ,why?
maybe it’s the wrong clutch? For another car , it’s happened before with suppliers or maybe the wrong bolts fitted restricting the cover .
I think a ball park of how hard it is to push would help or what if the slave is removed ,does it shoot out without load .
Has the clutch always been heavy or after replacement only
