lambada sensor
nismoboy
ive had my lambada sensor checked at a local garage and a guy there told me that its not switching? and that theres a permant 1.9 volts at the switch wire?? any ideas :?:
jasegould
Either the sensor is kaput and stuck on 1.9 v, or the fuelling is kaput and the sensor is ok.....Id be tempted to change the sensor. If you have the emissions data (co, O2, HC and lambda) ill be able to tell you which one it is when i get to work.
nismoboy
The guy at the garage who told me that the sensor wire was reading 1.9v and hes also put a probe in the exhaust and it read 1.09 which he said is a little bit lean any ideas??
