E
Edd
Right i will just explain how my car's been behaving and what i've had done over the last month or so then tell you what i've done and i want you to diagnose the fault
:? :roll:
Had car set up at powerstation back in august. It was pinking quite badly and they had to retard the ignition quite a lot to stop it from pinking.
Got 172 @ the wheels compared to 175@wheels back in may.
Since then noticed a slight misfire off boost on the car. Anyway two weeks ago i decided to service it. (by the way my plugs are std pfr7b-9 gapped to 0.9mm and have been fine)
I replaced dizzy cap, rotar arm, fuel filter, basically everything EXCEPT leads. The plugs i fitted were NGK race plugs (later found out to be gapped to 0.62mm)
Anyway misfure was still there and car ran exactly the same so i thought
Went to a rolling road shootout and got car on rollers and got 206bhp @ fly @ 5600rpm
operator said it was missing badly due to being under load and didnt want to rev very well and they thought the boost was blowing the spark out.
SO i rang powerstation and then i regapped my old plugs to 0.7mm and fitted them. Drove the car and it fookin flew, revved like it used, and was really quick (well compared to how it was not wanitng to rev fast)
Also point out that turbo is spooling up fine..
Anyway 2 days later and nothing else changed and the car goes slow again
Don't know why and havent changed the plug gap yet.
today i tested the spark from the HT leads.
Unplugged each lead while it was running and arcd it off the cam cover. LEads 1-3 sparked on a random cycle and slowly Lead number 4 kept zapping repeatedly approx 4/5 times per second and constantly whereas 1-3 kept changing how often it sparked.
So i plugged the end of lead number 1 into position number 4 on the dizzy and ran the car on 2 cylinders :roll:
result was a good spark on lead number 1 unlike when its connected to number 1 on dizzy.
sooo is my leads?? (only thing not changed)
or do i have to look at the fact my coil, ignition module, or dizzy are fooked.
Car now has a huge miss where it wont even accelrate for about 3 seconds under load and it just doesnt want to rev :x
Help please :idea:
Help please :idea:
