hks cams???
G
gtiral
hi i am mid rebuild and the mechanic is wandering if the cams i ahve will fit straight in without having to re-shim or new valve springs etc they are 264's any help appreciated
he will still need to reshim it though as the clearances will be different unless hes very lucky
stumo
3,796
1
38
Bob, i think you need to add a few more "very"'s :lol::roll:
Davey, you've got to be kidding yourself if it didn't need re-shimming....
davey red.r
2,545
0
0
54
newcastle upon tyne
nope stu, they were just dropped in,i think steve would of charged me for the reshimming carry on for sure unless he done it but didnt mention it,, like a say its a bit lumpy on tickover,
but im hoping this can be tweeked when its rr /remapped.
davey
you were very very very very very very very very very very very very very very very lucky davey:lol: everytime ive changed a set of cams (even standard) the shims need to be adjusted, dont forget were talking in thousands of an inch difference here and its virtually impossible to have 2 cams with exactly the same wear rates on each individual lobe.
very very very very veryvery very very very veryvery very very very very
is that enough very's for you stu:lol::lol:very very very very veryvery very very very very very veryvery very veryvery very very very veryvery very very very ververy very very very very
davey red.r
2,545
0
0
54
newcastle upon tyne
for fcuks sake, i wish i hadnt said owt now:doh::lol:
guess im very lucky then,
about time something went right for me with this motor,
having now said that the tw*t probably wont start later:x:lol:
stumo
3,796
1
38
davey, you need some more "very"'s in there.....:doh:
8,701
104
63
Penkhull
I'm not very sure because I very much think that my engine was being very rebuilt anyway when the cams very went it.
I very though they were a drop in part, but I very much guess that you'd at least have to very adjust them a very little (hey that one actually fitted like it should) to get them very right (I'm on a roll now).
boost
508
0
16
ha ha this is "very" funny.. there seems to be very many peoples diffrent very many views on this cam fitment.. personally i would just install and check shim clearance.. and if anyplay then get some very shiny new ones installed! thats me done here.. phh children ;-) ha ha
G
gtiral
cheers guys for the conefusing read!!!
i have informed my mechanic sooooo should be done VERY VERY VERY soon hahaha
if the clearances are tight you will lose power as the valves wont be closing properly, this in turn will lead to valves being burnt out prematurely and possible damage to valve seat also. but your engine wont be rattly!
if on the other hand they are too loose (depending how loose they are) you may just experience a noisy topend 'which isnt really gonna cause any damage' but if the clearances are very loose then you heighten the risk of throwing a rocker which could lead to just snapped shims and rocker arms or it could lead to bent valves if a rocker gets jammed across the head of the valve.
thats why its very very very important to make sure they are reasonably well adjusted:lol:
why thankyou danny lol
pm me your tel number dan as i need to speak to you sometime regarding trackdays and your mates ballistic escort cossie! thanks
