High pitch whine only under load.
L
Little Erve
Hello all,
Another Aussie here :)
I've got a problem with my car. When ever I put my foot down hard it makes this high pitch whine noise but it doesn't do it in neutral.
Could a low oil level in the gearbox cause this? As my gearbox breather hose isn't connected.
Cheers,
Steve.
E
Edd
Does it whine if you rev it out of gear whilst stationary?
If it does its most likely either alternator or water pump belt
1300 miles and still intact
L
Little Erve
No, as I said, it doesn't do it in neutral. Either rolling or stationary.
sigh oh well I'll keep looking.. [:(][|)]
mine does this. i had the box rebuilt and it still does it. i reckon its a bearing in the transfer box. it hasnt got any worse in 2000 miles. drop your transmission oilsd and check for metal.
L
Little Erve
Crumbs [:(]
I was going to change my gearbox oil this weekend, seems like I'll also be changing the transfer case oil.
Thanks for the info, I was just hoping it was something simpler.
Cheers,
Steve.
mine did this and its 'mostly' gone away after gearbox,transfercase and diff oil change
