has anyone ever got a fault code 11 and 34 at the same time?
djdoc360
tryed to search the forms.....found alot of probles with 34 and some with 11, but i'm looking for someone that had both. i just did a engine swapp because my last motor seezed up on me(melted #1 crankshaft rod bearing). my old engine was fault code free every time i checked it(i check it at least once a month).so i took the old engine's det sensor and distribitor...put it on the new engine and set timming to 20 degrees... ran great. now i had a problem 2 days ago with spark plugs making my car run crappy.so i pulled them out and saw heat damage(plugs were a orange color). got some 9 heat range plugs ran good but not as strong as before. did fault code check and got 11 then 34. are the related or are there to different problems?
