GTIR Part codes
Status
Not open for further replies.
AJ4
Here is a .pdf that contains all of the pulsar part codes.
Use the first page like a menu, following the links takes you to what you need.
Its much easier to use if you right click and download it to your computer first before opening, reading it online is a waste of time due to the size. Its around 4 megs.
Note that these are the part codes, not the full Nissan part numbers. However, having the part code makes it much easier to find stuff on the Nissan FAST system.
http://www.gtiroc.com/parts/gtir_part_nos.pdf
http://www.gtiroc.com/wiki/gtirpartnos
the 4 rear engine temp/pressure sensors
1 sensor temp 2263051E02 £20.73
2 sending unit B507032J00 £76.54
3 sensor temperat 2508089907 2E3 £15.22
4 sensor ail temp 2507505U00 £49.53
As listed on my Nissan receipt.
If you go into Nissan with the part code and they look for something, make sure they are searching under:
Model series N14
Engine SR20DET
Grade GTI/R
Trans MT
WHL DRV 4WD
Speed F5
Area EUA
The only other info you may need is the paint code for coloured bits and the year of your car as bits tend to be grouped 90-92 and 92 onwards in alot of cases.
Status
