Hi
last night about 5 mins from home my gearbox went all funny.... basically it was mighty tough to put the car into gear whilst driving.. i pulled up at home, checked the clutch fluid... EMPTY
so..... i filled it.. pumped the pedal like fook for a min or so to try and bleed it a bit... the level stayed as it was... little bit of air came up... then jarred the pedal down for 3 hours... let it up slowly and topped up again...
(the best of a bad situation for bleeding it)
anyways... this morning... the little bitch didnt want to go into reverse and kept grinding... still no movement on the clutch fluid level.
i took it to the shops and fook me it would not have 2nd to 3rd gear change one bit... then it started to work fine with 2nd to 3rd and wouldnt do 3rd to 4th
Then it wouldnt do reverse and grinded a bit when i tried.
i drove it to work.. i get the normal jangle of my bearings in the HKS clutch when i press the clutch in and its still biting how it would.
its just being very tight and funny... any ideas people?
i can assume the master cylinder is knackered.. surely if my box was dead then it would have a definate sign.. like NO WAY will i go into 2nd ?
STUCK
