Fuel Pressure
gtir303
Can anyone help need 2 no fuel pressure that the 'r' runz at!
As we r changing the fuel pressure regulator @ the weekend!
zia
standard pressure is 2.5 bar if you,ve got a upgraded fuel pump it may be higher say 2.7-2.9
zia
zia
2.5 without vaccum which more less is 2.9 with vaccum!!
oh carl you may wish to change your profile mate!! :lol: :wink: a bit contradictory (i think that how you spell it)
zia
antilag
ginga told me today it was 42.5psi without the vacum pipe on?
gtir303
zia
even top mechanics need help sometimes
gtir303
zia
it shouldnt mater that i have an uprated fuel pump cause that only increases the fuel rate not the pressure it runs at,thanks for the info anyway :wink:
gtiroz
Administrator
just for clarification, from the manual:
section: EF&EC
pages: 638-639 (& 730)
fuel pressure: at idle
when fuel pressure regulator valve vacuum hose is connected:
approx. 245kPa (2.45bar / 36psi)
a few seconds after ignition switch is turned from OFF to ON:
(and when vacuum hose is disconnected)
approx. 294 kPa (2.94bar / 43psi)
8)
K
KrissJ
I've asked this question before as I have an adjustable fuel pressure reg and some numpty who had the car before me had turned it right up! :roll:
I set it up at a garage to 2.5 bar then took it for a test and it was spluttering like it wasn't getting enough fuel. Went back and turned it up to about 3 bar and it was fine. I've since experienced similar probs so have turned it up a little more and seems fine.
