Shaun said:
As i understood it the centre diff is in the gearbox and the front diff in the transferbox.
Sorry man my mistake you are right the front diff is in the transferbox :doh:
![Oops! :oops: :oops:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
some info that might help
ATTESA
ATTESA (acronym for
Advanced Total Traction Engineering System for All) is a
four-wheel drive used in some
automobiles produced by the Japanese automaker
Nissan.
History
The earliest model of car with Attesa is the 1989 2000SSS Attesa. However there have been reports of an 1987 RNU12 Bluebird (CA18DE) with the Attesa system, as well as a 1988 U12 Bluebird
There is also speculation that it was developed for Nissan's
rallying team. Although the Attesa system certainly has the potential to do well in rally motorsport, the Attesa parts are so rare and expensive, and awkward to work on, that it would be very uneconomic to rally with.
How it works
There are two distinct four-wheel drive systems in use which are both referred to as "ATTESA", one designed for transverse layout vehicles such as the
Pulsar GTiR, and the other designed for longitudinal layout vehicles such as the
Nissan Skyline GT-R (see
ATTESA E-TS).
The ATTESA system featured in the transverse layout vehicles, such as the
Pulsar GTiR and the
Bluebird Attesa modification, is quite similar to vehicles from other manufacturers. Drive passes from the gearbox to a centre
differential, which is then split to a front differential in the transfer case and via a tailshaft to a rear
differential.
This more conventional layout provides a 50:50 split between front and rear and utilises a centre
viscous limited slip differential to aid grip in slippery conditions. This system is commonly used in Nissan vehicles that are also available as front wheel drive models. This system is a full-time mechanical four-wheel drive.
