Flat spots and slight st-st-stutters...
pushermanR
Getting a bit of hesitation in the 2000 to 3000 rpm area last coule of days.
Plus what is the supposed rpm kick in for the turbo on Pulsars...
Running around 0.7 boost which feels real good in the high rev range....its just that hesitation it has in the lower rev range...
"This car is the ultimate look at the engine bay and scratch my head machine"
:lol: :lol: :lol:
one Gti-R
Sounds like a possible fuel surge.
other than that make sure your plugs are ok and gapped correctly, change your leads, rotor button and dizzy.
ki_saj_ng
if u feel that u have a flat spot, its probably down do ur injectors being slightly dirty and clogged up. you can get them bench flowed which involves them being taken out and washed basically. this can be done at not too much of an expense.
some geezer on here once had this problem and i think i have it and this was the solution, he was from aussie. i hadnt got round to doing it and now i cant cos i dont have a working engine so whats the point :x
saj
pushermanR
Could you get problems like this from the timing being slightly out...Seen alot on the forum saying it has to be spot on 2 get the most from your motor!!! :?
one Gti-R
Having your timing set right will make your car run a better than if its not but it will not have symptoms as you have described.
Anonymous
I'm the geezer which had that problem. :D
The injector cleaning help my problems with flat spotting. :D
