Fault Code 21 : Ignition signal circuit
I've been having a problem with the 'R ever since ben stuck a FMIC on. At first i thought it might have been a boost leak but i've triple checked every hose so im positive its not that.
The car seems to be fine but after 30 minutes of driving(hard driving, dont know what happens if i take it easy
:roll: ) it seems to miss fire at high rpm (5k+)
I have a turbo timer wired onto the 02 & ground sensor on the ECU so could it be something there :? ? I have a profec a boost controller but i've bypassed that and used a bleed valve so its not that. The problem only seems to occur at a bar, not standard boost.
I booted it in 5th gear and it went all queer then the loud pedal went all wierd and didnt accelerate like when the det sensor kicks in.
Anyone got any thoughts on the matter?
Thanks in advance.
Thanks in advance.
