Fault code 11
Tony
Car seems to bog down when accelerating!!!!
Did a check and it came up with fault code 11 (Crank angle sensor circuit)
Changed the dizzy for a known good one and did the voltage test to it and earth test between the earth and engine earth!!!!
Voltage ok at 12.summit volts!!
Multi beeps about 4 or 5 times when i go between 2 of the pins on the plug and a single beep on the last pin.
Should i have a continuous beep on 1 of the pins if it is to have continuity?
Any help guys?????? :cry: :cry:
Tony....
Tony
ooooops!!!!!!!
Tested the earth when the ignition was on!!!! :oops:
Turned it off and found the earth continuity is A-ok!!!!!!
Still got this problem and its really pi55in me off!!!!!!!!!!
Any ideas??????????
Tony....
