E
Evil_GtiR
Any big difference in performance if we get an after market front mount intercooler comparing to a modded front mount factory intercooler?
I've always wondered about this. people say the stock IC is fine once you're moving, surely that's all that matters anyway? :?donpulsar said:The standard top mount intercooler is good once you are moving ( so cold air is passing over it ) so the cheapest and possibly easiest solution may be to front mount the standard one ( and save $ on a front mount ) or keep the standard one and invest in water injection.
That is what I was wondering, I have an ARC top mounted intercooler 8) and I was planning on adding water-injection eventually as I thought that the only downside to having a top mount was because they suffer from heat soak?????why is the stock cooler so bad anyway ?
Just because of its location ? Or does it have more problems, like restricted flow or something ?
The flow will be restricted compared to an FMIC as there's less surface area in direct contact with cold air, i.e. it's lying down and not upright.WJ said:why is the stock cooler so bad anyway ?
I put the Forge on mine too, but as I'm running standard boost I didn't expect any difference. I got it as it was cheap.samellio said:I put the forge kit on my old car and despite costing the best part of 1k i got no noticable difference.. If anything the car didn't feel as sharp
If your going to run a lot of boost (1.2++++bar) this mod may be worth it but otherwise i don't think it's worth doing.
Sam
