Compression test help
I don't see why not, but you'll probably need to block the oil feed to the turbo off or something so it doesn't dump all the oil instead of circulating it around the engine. Same for the coolant, but more to save a mess than anything.
I did mine a couple of day's ago and it was: 157/157/160/157psi.
that's a standard engine :wink:
rob
mattygti-r
u wana tell the truth there Rob didnt kow standard engines had bits from SARD japan? lol
ok kinda need to know cos i think mines being done tomrorow
ive a compressoin test readout from the last owner and would like to know whats what
Well the inturnal's of my motor are standard as I'v not rebuilt it yet so the above reading's are for a standard motor.....
And I don't think a sard fuel reg would have any bearing on the matter do you :roll: :? .
rob
mattygti-r
thought you had uprated the internals at this point? humm okies thanks
my resuilts are abit different :shock:
what would an uprated engine say cams/head gasget etc give u? roughly
Olly
Compressions compression so when valves are shut they are shut so a set of cams should in theory make no difference at all, headgasket will make a change in the reading depending on thickness obviously. 8)
AJ4
And don't forget to disable the injectors or the dead fuel in the cylinder helps seal the pistons and gives better figures that what it is ;)
I didn't know that :oops: .
I'll have to try mine again
rob
gtiroz
Administrator
Factory compression:
Standard: 164psi
Minimum: 135psi
Difference limit between cylinders: 14psi
Standard: 164psi
Minimum: 135psi
pleased with mine then 8)
rob
